Trying to get the goblin started for the first time. Prior to this, the starter went bad and I had some bad grounds causing some electrical gremlins. After going through everything - I was finally able to see some progress, the dash would come up with no security light, the fuel pump primes and the starter starts right up. However, the car is not starting and is just dumping fuel out of the exhaust(so fuel pressure is definitely good). My first thought is to track down the ignition and figure why it's not getting spark. I pulled the codes and got the following:
P0033 - Turbocharger/Supercharger Bypass Valve Control Circuit / Open
P0449 - Evaporative Emission System Vent control Circuit Intermittent
P0452 - Evaporative Emission System Pressure Sensor/Switch Low
P05342 - A/C Refrigerent Pressure Sensor A circuit Low
The only concerning one I think would be P033 but I'm not sure if that would cause a no start condition.
