Lndshrk Steve
Is it the builders option or is there a correct way to route the parking brake cable around the rear A-arm? Above the A-arm and below the axle or below the A-arm?
Mine is along the subframe, above the A-arm and loosely tied to the tie rod. everything else is per the photo montage.Is it the builders option or is there a correct way to route the parking brake cable around the rear A-arm? Above the A-arm and below the axle or below the A-arm?
So THAT'S how those hook things are supposed to go... I just cut mine offMine are also above the control arm and below tie rod. The drivers side was slightly resting on the control arm, my somewhat temporary solution was to zip tie it to the tie rod.
View attachment 31816View attachment 31817
WhoopsSo THAT'S how those hook things are supposed to go... I just cut mine off
Nope.I find it funny that out of 300+ cars sold, there are probably 300 different examples of how to route a parking brake. Are any two alike?
"Its a line lock, duh"I’ll probably end up routing mine to the front wheels somehow. Considering I swapped my intake and exhaust cams.
CHRIS
Rock auto actually sells the entire parking brake cable (for SS/TC anyway) for a little over $12.If someone accidentally misplaced their support wires for the lines…where would they source them? Asking for a friend.
