CaptFrank2001
Since I am not using the emergency brake can I remove the Emergency Brake assembly from the Caliper. The bracket, spring, actuating arm etc... Seems like that would get rid of some clutter.
Um, no. Not for parking on a hill. Great for doing a brake stand!One of these works just fine for a parking brake too.
Line lock, manual brake lock, hydraulic brake park lock, pressure holder | eBay
(New brake lock line lock, hydraulic brake park lock pressure holder. This brake lock using hydraulic line pressure hold your brakes. For cars, trucks, Disc or Drum brakes. 2) push down the knob on the Brake Lock.www.ebay.com
Works fine for me, left on my steep driveway for 8 hours one day never moved.Um, no. Not for parking on a hill. Great for doing a brake stand!
"Note: it should NOT be used under unintended, emergency or long time hold brake. "
I said parking brake, not emergency brake and these work fine parking on a hill. I've used these in past vehicles including Jeeps and they will hold a vehicle in place. So unless you have some personal experiences with using a line lock in this manner, then you only have hearsay to go on. Thanks for your opinion.Um, no. Not for parking on a hill. Great for doing a brake stand!
For a base cobalt you reuse the front bake calipers and rotors in the rear of the Goblin. You get calipers and rotors for the front of the goblin from DF (you need to buy pads).Since I am not using the emergency brake can I remove the Emergency Brake assembly from the Caliper. The bracket, spring, actuating arm etc... Seems like that would get rid of some clutter.
