Resetting the Odometer - How To
Chubbs
EUREKA! I figured it out.
The issue is the 3.3 volts the CH341a programmer puts out. It's not enough. I reworked the CH341 programmer to output 5v to the chip, and it read right off the board. No need to desolder the chip at all. Just clip on and it reads. The voltage rework is here:
next issue was with TachoSoft. The version I downloaded (free, and probably pirated) did not have a 2007 Cobalt. only 2004-2005, and then another for 2006. However, you'll notice there is a pattern. on lines 3B0 and 3C0, there are some characters that repeat 3 times. All the other cobalts listed the same characters, so I just assumed 2007 was the same, and it was. Tachosoft was in kilometers, so I had to do that calc to miles, and it spit out a set of hexdata to change.
My car now has 5367 miles on it, which is a 5000 mile motor when I bought the car (new long block), plus the miles I've put on it since the build. It's approximate, but it's much closer than the 136k miles it showed before.
Keckster
perfect! I tried doing the 5 volt mod but ended up breaking programmer and haven’t tried since. Thanks for doing the extra research and checking if that was the issue!
Cnixon160
Anyone ever unintentionally add a bunch of features to the cluster menu while resetting their mileage? I somehow managed to add all of the power lock, tpms, remote start, and keyless entry options to by 2010 XFE base model BCM, I saved both BIN files and the only change is the four bits in the three locations being zeros but I have much more listed now
NextFungus
New Member
Do you have a way to verify you didn't already have the options?
