I am glad I am not the only one dealing with this issue. I have found this to be the case with my set of shocks as wellUnfortunately, I am just a home builder with basic tools. I don't think it is too much to expect brand new parts from the same manufacturer to fit together out of the box. We're not talking about tolerance stack between parts from different manufacturers - these are parts built, boxed, and sold by the same company. Issues happen in manufacturing and as long as manufacturers make an effort to correct quality issues it's no big deal.
However, to suggest the issue was caused by someone else as the first step in addressing the problem even though it is a known issue is not acceptable. Taking over 3 weeks to do something you said you would do and needing multiple follow-ups to do so is also inexcusable. After this experience, I won't be using anything QA1 again if I can help it.
Did you also have clearance issues when mounting the turbo to the exhaust manifold? My Z54 comes in contact with the manifold very slightly (this is without the heat shield on the manifold. With the heat shield installed, the turbo really cannot be mounted.Hey @Sluggonaut, finally got my stuff plumbed up. Here’s the vent tube from the valve cover. It goes straight to the turbo housing according to zzp’s install instructions for the z54 and z57 turbo. I’d assume your ko4 is similar. If not, then put a catch can on that port (oil line from valve cover to catch can, filter on outlet port of catch can).
I forgone the option B tank as there wasn’t much room for it with the swooping corners I had to do with the straight hose I had to avoid kinks. It put the lines higher than I wanted to mount the option B tank. So I reused the Factory fill neck and it’s the highest point in the system.
View attachment 31678View attachment 31679View attachment 31680
I did not have any clearance issues. My donor was turbo-swapped so the only adjustments I had to make when installing the motor was to re-clock my K04 to clear the frame. However, I probably wouldn't have even needed to do that had I found the shorter intake flange provided in DF's turbo kit prior to bolting the motor in.Did you also have clearance issues when mounting the turbo to the exhaust manifold? My Z54 comes in contact with the manifold very slightly (this is without the heat shield on the manifold. With the heat shield installed, the turbo really cannot be mounted.
As I recall, I had about the same result cleaning with brake cleaner (ineffective). I had better results soaking the cores in a bath of water and Dawn dish soap, then "drying" with compressed air. Rinse and repeat. The dishwater was pretty dirty afterward. The cores didn't look like new when done, but far better than when I started.I was expecting them to be much dirtier. I still used a toothbrush to try and get some dirt off but the brake clean was still clear in my pan after spraying and brushing these.
What did you use to clean the PCV valve? I realized it's impossible to find now, so cleaning it is a good idea.As I recall, I had about the same result cleaning with brake cleaner (ineffective). I had better results soaking the cores in a bath of water and Dawn dish soap, then "drying" with compressed air. Rinse and repeat. The dishwater was pretty dirty afterward. The cores didn't look like new when done, but far better than when I started.
While the cores are out, take the opportunity to clean out the intake. Mine had an ounce or two of oil I literally poured out. Also, if you already have the intake manifold off, pull out the PCV valve and give it a good cleaning too. Easy and free preventive maintenance - my favorite kind.
I had some oily residue by the ports but that cleaned up easily with brake cleaner. I think the intake manifold was serviced on the donor fairly close to when I bought it, as it didn't look like it had 140k miles of crud built up.
Pretty sure I cleaned mine with brake cleaner. I followed this video and it worked out well.What did you use to clean the PCV valve?
Mine is the entry-level turbo swap from ZZP, so I have the stock LSJ intake - hence the laminova cores mentioned above.@Sluggonaut -- if your Goblin is a turbo model it has a different PCV than the one posted before for the Saab. Rock auto shows they have the turbo ones for an 2008 model 2.0.
But if you have the aftermarket turbo conversion, and have used the Supercharged intake bottom side, then you might use the Saab PCV.
The box I gave to Lonny had both SC and turbo model PCV.
