Dsteinhorst
Not coming up with much while searching. It would appear that the smog/air pump indicates my G5 is a California car. Is that correct?
What state are you in? Will you be exempt from emissions testing? If so, get rid of the EVAP, EGR, and you will want to research the PCV valve info here on the forum.NU6. Ugh. It's just the fuel pump that's different, and I can pull all this smog pump garbage off, right?
That is used in places where the states have tighter emission standards not just California. My PA car had it. It is called Secondary Air Injection (SAI). Yes you can remove it. It will however determine what header you will use See this post . Your car has the NU6 code that is a PZEV does it have the XFE logo on the decklid? If so JSATX and I have used the same donors. If it has the XFE it will have the FY1 code for a 3.63 axle ratio Vs. the 3.82.Not coming up with much while searching. It would appear that the smog/air pump indicates my G5 is a California car. Is that correct?
I bought a non PZEV fuel pump and a pig tail for my car and it all worked out good. I have the numbers and where I got them at if you want. If you haven't yet do not bother pulling the fuel tank there is nothing there that you will use.NU6. Ugh. It's just the fuel pump that's different, and I can pull all this smog pump garbage off, right?
Karter, can you post or PM me the fuel pump pigtail part number? The generic Ebay one I got was wrong. Thanks!I bought a non PZEV fuel pump and a pig tail for my car and it all worked out good. I have the numbers and where I got them at if you want. If you haven't yet do not bother pulling the fuel tank there is nothing there that you will use.
