askiles
Which sensor could be reading it incorrectly? I know the MAF is fine, I actually swapped it with a new unit and it did not change anything.Wonder if any sensors are reading incorrectly, making it believe their is a leak....
I have a ground ran directly from the battery. I went ahead and did that to several locations in the car. I didn't want any ground issues.Got a good engine ground? Jumper cable from the battery to the engine to check.
****, you're on it at least.I have a ground ran directly from the battery. I went ahead and did that to several locations in the car. I didn't want any ground issues.
Right?!? I am glad it was this easy.Crazy, glad you found it!
Oh it did. No more crazy surging idle. It surges a tiny bit now, maybe 1-200RPM’s, but very sporadic and not all the time, but I have heard this is very common and just is what it is. I went and drove it around, and I am loving it!!! That instant boost and whine is amazing.Andy, I hope this fixes your engine issues. It will be good to have your car on the road soon.
That's crazy! And frustrating that someone else's incompetence has caused you so much aggravation.No need, I found the leak in the air system. The guy who rebuilt my supercharger left one of the bolts on the snout off. I smoke tested it and smoke came pouring out of the hole. Now to bolt it up and hope that fixes it. I’m actually surprised no supercharger fluid comes out of that hole.
When I sent him the supercharger to be ported and rebuilt, one of the bolts on the snout hosing was different than the rest. It was just a cheap hex head bolt that someone put in there. ...and it was leaking fluid. When he rebuilt it, he didn’t put that one back in. He should have thrown something in there. I also should have noticed it I guess. Oh well. Easy fix.That's crazy! And frustrating that someone else's incompetence has caused you so much aggravation.
Did he put new fluid in? One would assume that he did. Since I had ours off, it was easy to dump it out and refill it for insurance.When I sent him the supercharger to be ported and rebuilt, one of the bolts on the snout hosing was different than the rest. It was just a cheap hex head bolt that someone put in there. ...and it was leaking fluid. When he rebuilt it, he didn’t put that one back in. He should have thrown something in there. I also should have noticed it I guess. Oh well. Easy fix.
He sent a bottle of new fluid back with the supercharger, and I filled itDid he put new fluid in? One would assume that he did. Since I had ours off, it was easy to dump it out and refill it for insurance.
