TheDons track, easy entry, 09 ss/tc build #273
TheDon
Yea im not the first I saw it on another build just kept playing with it in the vice. Not bolted tight in pic. Next will be cutting for the front vents. Read a few logs but if there's any tricks let me know
TheDon
Felt like I was due for an update, the state (Maine) doesn't seem to want my money I will have to do Montana route. Verified coolant system is working as it's supposed to last night. Still haven't seen intercooler pump kick on?
Your inter cooler pump should come on all the time. Depending on the setup in the ECM, I have it set to come on with the ingition.
TheDon
Thanks for confirming I may have an issue then, I've never seen it on before. I used clear tubing
There is a setting in HP Tuners that sets the delay for the coolant pump. Default is 10 seconds after the ignition key is turned on, then the pump starts, runs until the key is turned off.
Are the ECM intercooler settings relevant for an SS/TC? I thought only the SS/SC tunes had the A2W intercooler pump stock.
You are correct, not available for the TC. It's hard to keep up with who has what donor. It's in the title for this one, but I often forget to look there, and the signature doesn't show on the phone.
Unfortunately it's not in a signature not on mobile, either...
Mod your signature here.
