Tires and Wheels List Updated on 3/25/2020
JeffsGoblin
Please make sticky at the top of this thread:
12389
Updated list (3/25/2020) of chassis number, frame/color, donor year/engine, installed wheels, wheel weight, tires and seats on everyone's Goblins. I need help filling in the blanks. Please send me the following info and I'll add it to the list (or send corrections if needed):
Goblin Builder:
Chassis Number:
Frame Type / Color:
Donor Year / Engine:
Wheel Make / Model:
Front Wheel - Size / Offset / Bolt Pattern:
Rear Wheel - Size / Offset / Bolt Pattern:
Wheel Weight in lbs.:
Tire Make / Model:
Front Tire Size:
Rear Tire Size:
Seat Make / Model:
Click on list to make full screen and easier to read.
Thanks,
Jeff
Gsd autos mn
Great job Jeff, I looked at every build for days just to get the chassis info you posted. I know this is very helpful.
BaltimoreHokie
Goblin Builder: Manny
Chassis Number: 74
Frame Type / Color: City, Copper Vein
Donor Year / Engine: 2007, SS/SC 2.0
Wheel Make / Model: Konig Oversteer
Front Wheel - Size / Offset / Bolt Pattern: 17x8/+35/5x114.3
Rear Wheel - Size / Offset / Bolt Pattern: 17x8/+35/5x114.3
Wheel Weight in lbs.:19.9
Tire Make / Model: Falken Azenis
Front Tire Size: 235/45/17
Rear Tire Size: 235/45/17
Seat Make / Model: Corbeau, FX1 Pro
Build Thread: http://dfkitcar.com/forum/index.php?threads/mannys-city-goblin-07-ss-sc-donor.559/
KLMOTORSPORTS
Goblin Builder: Ken Leiker MotorSports
Chassis Number: 126
Frame Type / Color: Track / Black
Donor Year / Engine: 2007, SS/SC 2.0, F40 Trans
Wheel Make / Model: TBD
Front Wheel - Size / Offset / Bolt Pattern: TBD / 5x114.3
Rear Wheel - Size / Offset / Bolt Pattern: TBD / 5x114.3
Wheel Weight in lbs.: TBD
Tire Make / Model: Hoosier A7
Front Tire Size: TBD
Rear Tire Size: TBD
Seat Make / Model: Kirkey / 65185
Build Thread: http://dfkitcar.com/forum/index.php?threads/ken-leiker-motorsports-track-07-ss-sc-donor.902/
Builder: Tim
Chassis number: #155
Frame type / color: Track/Extended / White (POR15+2K)
Donor / Engine / Trans: 2008 SS/TC / Crate LNF / F40 w/Quaife LSD
Wheel make / model: Vors TR4 white 5X110
Front wheel size: 17X8 35mm offset
Rear wheel size: 17X9 30mm offset
Wheel weight: Front 16.5lbs, Rear 17.5lbs
Tire make/model: Federal 595RS-R
Front tire size: 225/45-17 25.0 inch diameter
Rear tire size: 255/40-17 25.0 inch diameter
Seats: Ikon Motorsports RS01
Build thread: dfkitcar.com/forum/index.php?threads/desert-sasqwatch-track-extended-08-ss-tc-lnf-f40.1003/
wombat
Goblin Builder: Wombat
Chassis Number: 20
Frame Type / Color: track / kawasaki green
Donor Year / Engine: 2007 SS SC
Wheel Make / Model: 6UL
Front Wheel - Size / Offset / Bolt Pattern:15x8 / +36 / 4x100
Rear Wheel - Size / Offset / Bolt Pattern: 17x9 / +45 (need spacer) / 4x100
Wheel Weight in lbs.: 11.6 front / 15.4 rear
Tire Make / Model: hankook rs4
Front Tire Size: 225/45/15
Rear Tire Size: 255/40/17
Seat Make / Model: NRG
extended studs
Goblin Builder: Ross
Chassis Number: 121
Frame Type / Color: Easy Entry Extended City / Rustoleum Gloss White
Donor Year / Engine: 2006 SS / 2.0 Supercharged
Wheel Make / Model: OE Wheels Mustang Cobra R 98 Deep Dish Wheel
Front Wheel - Size / Offset / Bolt Pattern: Size: 17" x 10.5" / Offset: +27mm / 5x114.3
Rear Wheel - Size / Offset / Bolt Pattern: Same as front. Spacer were used both front and rear.
Wheel Weight in lbs.: 24
Tire Make / Model: Nitto NT05R Drag Radial Tire
Front Tire Size: 315/35R17
Rear Tire Size: Same as front
Seat Make / Model: Cobalt SS Seats
9505
JeffsGoblin
Just curious, are drag radials legal in most states or not? I would suspect no, but they do have a little bit of tread on them. From my wheels and tires list, you got the widest so far. Its gonna look sick!
Those Nittos are DOT compliant, so yes, they are street legal.
The tires do wear quickly, have poor wet traction, and aren't quiet running. Not that I am looking for wet driving conditions.
ccannx
Just wondering if this list includes wheels that needed spacers to fit. I'm still trying to figure out what offsett I need to run to get a 15x10 stuffed under all four corners.
There is a bunch of math on spacers here.
The Cobalt studs are about 32mm longer than the brake disk, so any spacer smaller than 32mm would require trimming all the wheel studs.
I ended up with 39mm spacers on 17x10.5 wheels.
