Tires and Wheels List Updated on 3/25/2020
Lethalcast
Goblin Builder: Chad
Chassis Number: 89
Frame Type / Color: extended city easy entry, cobalt metallic
Donor Year / Engine: 2009 TC
Wheel Make / Model: Konig Tandem
Front Wheel - Size / Offset / Bolt Pattern: 16x7.5 40 offset 5x114.3 17.59lb
Rear Wheel - Size / Offset / Bolt Pattern: 17x9.5 15 offset 5x114.3 23.38lb
Tire Make / Model: Toyo Proxes R1R
Front Tire Size: 225/45 16
Rear Tire Size: 275/40 17
Seat Make / Model: Braum Elite series/ Black Suede
9550
Motoracer110
Chassis Number: 89
you inspired me to get the same tire setup they look sweet!
Mayor West
Goblin Builder: Mayor West
Chassis Number: #191
Frame Type: Extended Track
Color: Nardo Grey & Black Cast
Donor Year / Engine: 2009 SS/TC
Wheel Make / Model: AVID.1 AV06
Front Wheel - Size / Offset / Bolt Pattern: 17x9 et42 5X114.3
Rear Wheel - Size / Offset / Bolt Pattern: 7x9 et42 5X114.3
Wheel Weight in lbs.: 16.4
Tire Make / Model: Nitto 555 G2
Front Tire Size: 245/45/17
Rear Tire Size: 285/40/17
Seat Make / Model: Braum Elite-X Denim
Harness: Impact Racing 5pt
Wing: Seibon GT with DF Mounts
Goblin Builder: Jason Backs (JBINTX)
Chassis Number: 186
Frame Type / Color: Ext. Track Bentley Blue PPB4711
Seat Make / Model: Cobalt SS / RaceQuip 741001 Sportsman 5-Point Camlock Harness Set
Street Wheel Make / Model: Klutch ML7 brushed silver
Street Front Wheel - Size / Offset / Bolt Pattern: 17x9 20 5X110 mm
Street Rear Wheel - Size / Offset / Bolt Pattern: 7x9 20 5X110 mm
Street Wheel Weight in lbs.: 23
Street Tire Make / Model: Proxes R1R, 27 lbs
Street Front Tire Size: 275/40/17
Street Rear Tire Size: 275/40/17
Track tires 15x10 American Racer 23.5/10.0-15s (M28 compound)
Track wheels Aero Race wheel 50 Series 50-104550 15x10 with 5" back space (these clear the calipers on the 09 tc SS model), Day motor sports 800-543-6238)
Track wheel spacer/adapter - 1" to get from the 5x110 to 5 on 4.5"
Track tire and wheel weight 43 lbs
Todd M
Goblin Builder: Todd & Brenden Mohler
Chassis Number: 179
Frame Type / Color: Ext. Track, Illusion Cherry powder coat (PMB-6905)
Donor Year / Engine: 2006 SS/NA 2.4L (full rebuild with forged internals, neutral balance shafts, ATI race damper, turbo coming soon)
Wheel Make / Model: Motegi Racing - MR131 TRAKLITE Matte Bronze
Front Wheel - Size / Offset / Bolt Pattern: 17x7, 45, 5x114.3
Rear Wheel - Size / Offset / Bolt Pattern: 7x8, 40, 5x114.3
Wheel Weight in lbs.: Front 16.94, Rear 17.6
Tire Make / Model: Continental EXTREMECONTACT SPORT
Front Tire Size: 225/45ZR17 W
Rear Tire Size: 255/45ZR17 W
Seat Make / Model: Corbeau FX1 Pro
Chassis Number: 179
Todd, Brenden, welcome to the forum. You sneaked in under the radar, but not for long. Will you be starting a build log? Have to assume you have been reading in the forum to know all the recommended stuff.
Dang! That was your first post Todd? Looks like you got plenty of details figured out already.
Great to have you aboard!
Todd M
Thanks guys. Not really a avid poster, more of a reader :). I have been reading in the forums since before we decided to start the order/build.
I think we will put together a build log, probably as we get a little closer to the end. My son has even done video of some of it for timelapses.
In the meantime, here are some pics...
nice job on the engine cleaning!
Vwsaabvt
Goblin Builder: Andrew
Chassis Number: 151
Frame Type / Color: Extended Track/Dragons Blood
Donor Year / Engine: 2006 LSJ
Wheel Make / Model: XXR 530
Front Wheel - Size / Offset / Bolt Pattern: 16x8.25 0 Offset 4x100
Rear Wheel - Size / Offset / Bolt Pattern: 17x9.75 25 Offset 4x100
Seat Make / Model: Braum Elite R
Goblin Builder: Russell
Chassis Number: 184
Frame Type / Color: track/safety yellow
Donor Year / Engine: ‘06 2.0L supercharged
Wheel Make / Model: Vertex RTX satin black
Front Wheel - Size / Offset / Bolt Pattern: 17x7.5 5-110
Rear Wheel - Size / Offset / Bolt Pattern: 17x7.5 5-110
Tire Make / Model: Toyo R888R
Front Tire Size: 245/40ZR17
Rear Tire Size: 245/40ZR17
Seat Make / Model: NRG RSC-208 W/cobalt mounts
Goblin Builder: Rauq
Chassis Number: 240
Frame Type / Color: city/gray
Wheel Make / Model: Motegi MR147
Front Wheel - Size / Offset / Bolt Pattern: 17x8 5-110
Rear Wheel - Size / Offset / Bolt Pattern: 17x8 5-110
Wheel Weight in lbs.: 18.6
Tire Make / Model: Falken Azenis RT615K+
Rear Tire Size: 225/45ZR17
Seat Make / Model: Corbeau FX1 + DFKC mounts
Chassis Number: 184
Update on wheels and tires:
Forgestar F14
Semi concave
Matte black
17x9 all around
65.1 hub
5x110 bolt patern
Backspace +10
Front tires Toyo Proxis R888r 245/40-17
Rear Toyo Proxis R888R 275/40-17
Chubbs
Does anyone have a favorite website for shopping for wheels? Specifically, I'm looking for a staggered set, probably 17x9 in the rear, and 15 or 16 inch in the front (maybe 6.5 or 7" wide).
The problem is finding a website that will filter by lug pattern (I'm on 5x110 still), AND filter for a matching set with multiple diameters. For example, on Tirerack, I have to filter for 17x9 wheels in 5x110, Find one I like, THEN filter for the same thing in a 15 inch wheel, and just hope I find a matching wheel in that size. I can't figure out how to filter for a matching set in both 17 and 16inch sizes.
So far, I have found no wheels that match my criteria, and the process takes forever going back and forth between sizes. It looks like Konig makes a few that would work, but they are only in 5x4.5 lug pattern.
I usually will buy from EBAY or Summit Racing.
Todd M
I usually find a set I like and use the manufactures site to find the part number for the correct lug pattern and bore. Sites like Konig, Niche, Motegi, etc.
ColoradoCryptoTrader
Goblin Builder: Adam T - coloradocryptotrader
Chassis Number: 333
Frame Type / Color: full cage full door bars extended / Prismatic Evo Grey PMB-5969
Donor Year / Engine: 2008 LNF
Wheel Make / Model: Vors TR4 machined silver
Front Wheel - Size / Offset / Bolt Pattern: 17x9 / offset 30 / 5x114.3 (using 5x100 to 5x114.3 adapters)
Rear Wheel - Size / Offset / Bolt Pattern: 17x9 / offset 30 / 5x114.3 (using 5x100 to 5x114.3 adapters)
Wheel Weight in lbs.: 22.7
Tire Make / Model: Nitto NT555 G2
Front Tire Size: 275/40/R17
Rear Tire Size: 275/40/R17
Seat Make / Model: Corbeau Baja XP
33064
