Agree, I was trying to find a video on this. I swear I saw an EngineMasters video on that forever ago that showed basically no change. Can't find it though...Dimple the pipe a bit to clear the bar. It won't affect power.
No links yet. Im going to build adjustable links with rod ends.Which links are you running. I think some are shorter than others. The shorter ones rotate that kink a little lower and may allow it to clear. Mine is close but doesn’t hit.
Then make them short enough to rotate that kink down.No links yet. Im going to build adjustable links with rod ends.
I’ll take a look and see if it clears if I can get it rotated down.Then make them short enough to rotate that kink down.
Does adjustable sway bar links make much difference when you can adjust the coilover length to adjust weight balance?
Good catch. Looked right at that and missed it when focusing on the swaybar issue.It's been a while since I've looked, but I'm pretty sure your toe-link bar is on upside-down.
It should be elevated above the subframe, like this:
It will drop down into the recess as the suspension is compressed but it might need to shift sideways some also.Is it possible the sway bar is on wrong as well?
I ran the sway bar on mine with DF supplied exhaust for a while and it cleared just fine. The part that sticks out that seems to be hitting on yours is supposed to sit down in the recess of the subframe I believe.
Thanks! I’ll flip it overIt's been a while since I've looked, but I'm pretty sure your toe-link bar is on upside-down.
The Car is still on jackstands. I guess before I do anything too drastic let me get it on the ground and see what the bar does.It will drop down into the recess as the suspension is compressed but it might need to shift sideways some also.
