I did consider that for a bit. But with the quality of studs there initially, I'm not sure the rest of the hub is better and I don't want to guess.Just go buy 8 new studs.
Yep, and you ain't going to like it. Hit the end of the knuckle with a hammer. This will slightly deform it enough to push it out. This is an old trick that always works but can damage the finish. Maybe try it the first couple of times with a piece of hardwood between it and the hammer.We changed out the rod ends so that the short ones were on the front. Then trying to align the uprights close to what they should be, we tried to take off the rod end but it was stuck hard. Tried using penetrating oil and even a 3# sledge to try and knock it out with no luck. Any tricks of the trade out there to get conical rod ends out?
