V1 BAR-AIR's build up in Buffalo N.Y.
BAR-AIR
Red Rectangular Block on the BCM
BAR-AIR
Good Evening,
Alright that is the end of the electrical notes. I tried to use the OEM Orientation and numbering (lettering) if I could or even if I could see it. If I couldn’t everything is oriented to each other so they are completely interrelated. From everything together you could probably start with new plugs and blocks and be able to build the wire portion to lengths of your desire.
This is just me so there may be discrepancies (give me a call or text and I’ll update as necessary) there are also some ”?” if you have the location or the correct connector name again let me know and I’ll update.
THX Again,
Bruce
[email protected]
You have to get though this to get to...
THIS....
Above are 13 individual posts with each of the BCM, ECU and Main Fuse plugs and fuse blocks. Broken down into wire color codes and where each of those wires begins and terminates....
I wish I had your note taking skills. Your hand writing reminds me of Forest Mims - the author of some entry level electrical engineering books I use to read as a kid.
BAR-AIR
Good Afternoon,
On the road working with my electrical notes. One of the things I wanted to figure out was the interconnections between all the BLOCKS & PLUGS. (Basically so someone -if so desired could move the BCM, Main FUSE BLOCK & ECU and place them anywhere room allowed for with in the car) but to do that you would need to know how they interconnected (was having difficulty trying to do that with standard diagrams).
I‘ll clean it up when I get back home but I think it is still readable.The thing that is impressive is that there really isn’t a lot of wires that are interconnected (one could really streamline the entire electrical system) with still using the OEM equipment.
Bruce
BAR-AIR
Good Afternoon,
Basement gathering of Goblins... jockeying cars around so Nathan can push his car out to try his new stand alone !!!! Hopefully a better out come then the last try with the folks from Alpha Fab (major F@#$ing ).
Bruce
Either way Nathan will update his build log with a thumbs up or thumbs down... Either way I would also like to give Rich a shout out from RDM ECOTECS for not only building the new stand alone harness (which looks awesome) but actually answering phone calls, texts and emails usually on the the same day!!!
Bruce
Well they are back to bed under covers...
BAR-AIR
Good Evening,
Family member was going to scrap it so it followed me home for a quick remodeling job before heading to the scrap yard. (A running driving bare bones 2007 no power windows or anti skid... 157,000 miles with a bad alternator - alternator was the straw that broke the camels back but a new starter). Probably end up pulling the harnesses, steering and brake assemblies, engine and transmission with axles... but leave the cradle and suspension (would change them out anyway)...
THX,
Bruce
If anyone needs anything from it let me know...
BAR-AIR
Good Evening,
Was working on a drivers side seat track slider for the BLUE car. (Now that my wife seems to want to drive it, without putting blocks on the pedals for her)... Seeing that it is a completed and powder coated frame really didn’t want to start cutting and welding. So I’m just going to put a couple of pictures in my build log. And do a better write up in a different log.
Here is a set of OEM drivers side seat tracks from the extra donor car that I had. (Really not interested in have the passengers side seat move forward prefer to have it in the aft most position for driving visibility)...
Working on a combination of the DFKITCAR’s seat mount and a standard universal seat mount getting bolted into the OEM seat track.
THX,
Bruce
