V1 Base model wire harness instructions
Jmar1622
Jmar1622
I'm planning as much as I can before I hopefully start my project next spring. So I decided to go through the wire harness videos and make instructions. They are mainly for a base, but are ment to be used in conjunction with the videos if needed. I cannot attach the pdf and Google docs changes the format. So if you want a copy, message me with or post your email and I will send them to you.
Jmar1622
I noticed a formatting error, so I fixed that and broke this into 3 files so it would upload here. If it doesn't work let me know.
Corgithulhu
Wow, your timing is impeccable. I am getting to the point where I need to fix a wiring mistake with my turn signal switch that I made during the harness videos, and these should come in very handy since I can search the document for key words. What a major effort here!
