Adam in CLE
- Adam in CLE Well-Known Member
I have the same connection as everyone. Hard to see it with the motor and fuse box in.take a picture of where your clutch line connects at the transmission and post it here.
sorry, will post one in a bit.I think there should only be one seal, but it's hard to follow your question. Maybe a picture?
Hi Rauq. No residual fluid or anything coming from the top. Was able to take a look inside and not seeing anything there. Thought it was brake fluid but could be oil from a bad main seal. Going to test a bit more and see if running the motor (has been sitting for about a year) could help seat anything and solve the issue.As a last ditch to stave off having to separate the drivetrain from the chassis, there's no chance you're looking at residual fluid from bleeding or anything like that, right? I've gotten halfway through bleeding before, only to realize my drain hose wasn't fully seated on the bleed screw.
Only other places it could leak are the threaded side of the clutch pipe or a leaky slave cylinder, and yes, you would have to pull the motor to do either.
