Based upon the mechanical skills of some of the people building Goblins, I wouldn't drive one built by someone else without putting a wrench on every nut & bolt on the car.
- I bought four 660lb package stand and decided to take them apart and use Arduino to link them all together and get different parameters. Keep in mind I have never coded in my life or messed with micro boards. I finished everything up and its reading perfectly. The 4 scacles will run a rechargeable battery that should last about 10hrs. For the screen anything can be used from a tablet to phone.
Unfortunately they are plastic, let see how much they hold up. Didn't want to order some expensive ones as I wasn't sure if my idea was going to work.Love the package scales idea! is the underside/body of the scales plastic or did you find a set that was fully metal? I used a set a while ago but the plastic body started to crack after a few uses and they lost their accuracy...
