ncgoblin
- ncgoblin Goblin Guru
Hey guys I have an odd ground issue. Driving my LSJ is great but as soon as I come to idle the throttle becomes nearly unresponsive and rough idle. I can power the engine off and back on and all is normal while driving.
I checked the voltage at the PCM module positive terminal and it was like 16-17v but checking at the alternator was 14v. This winter I reorganized my wiring in the front of the goblin and re-soldered my grounds and merged to the foot pedal box. I did leave (1) ground not terminated but this I believe was for Aux power.
1. Would it be possible for this un-grounded wire to cause issues?
2. What method would you take to identify a grounding issue? I noticed this part after watching a youtube video which may help. I was also thinking of removing all fuses except for mandatory fuses to run.
Thanks all
Thanks all
