V1 Ghostknife's #383 Track SS/SC
Sounds like when I had a high speed LAN issue. Data isn't flowing. But if I jumped the starter, the engine would run.
Ghostknife
Yep nothing, no lights, nothing happens on the key turn. Left the key in the on position while I wiggled wires to see if I could get a flicker on some sort. Got nothing. Almost like a fuse went on the whole car. Lol
This should be easier to track down than one particular circuit that doesn’t work. Something pretty major isn’t making connection on either the hot or ground side. Does your headlights and/or brake lights work?
Did you check the big fuse on the battery positive terminal? Have you checked your grounds? Have you checked the battery to ensure it’s not dead?
