So yeah… made a fun discovery yesterday…
I’m trying to get the goblin back together and I’m finally to a point to try and start it… except, it tries to start as soon as I hook the battery up…
Some beating and banging and cussing later, looks like the brand new starter I got has a bad solenoid so it’s getting RMA’ed…
Yeah… fun times….
You can definitely smell fuel and the spark plugs are wet. Over the last couple days, we've probably cranked the engine for 10-15 minutes.Assuming you are using gas and nor E85, if you pull the spark plugs after cranking, do you smell fuel? Since it did run for a short period of time, have to believe the electrical is (mostly) working. How long have you cranked the engine? Could be a lot of air in the system and it takes some time to work itself out.
I was starting down the timing path. The valve cover was the easiest to remove so I started there. I was going to pull the timing cover and oil pan too but I saw those broken bits so I stopped there.Oh no! that's not good. That will definitely prevent a start, sorry about that. How did you decide to remove the valve cover?
