1. I have never removed the engine harness. It goes wherever the engine goes.
2. No turbo yet... so no idea.
I removed the V band adapter, but it looks like that this is not just a simple adapter, it has the waste gate mechanism in it. Send cut send won't be an option. I guess I'll just go with the V Band and see how I can figure that out. Still no hint what turbo I have besides the AR50 M12 no other sign which manufacturer or so.Yes, that is also correct. You could just remove the V-band adapter.
I thought you couldn't disable VATS on an E69?I am in the process of relearning the key. I deactivated the VATS with HP Tuners, but thought I relearn the key before I swap engines. I switched it back on with HP tuners and I thought the procedure is switch the ignition on for 10min until the VATS light goes off and repeat that 3 times.
Unfortunately, the light only switched off one time. I have 2 keys and tried the procedure with both keys. No Luck. However, with one of the keys, the car starts for a second and then goes off, while the other key doesn't even start the engine.
Any ideas what I could try?
You can't, at least without knowing the secret. I've seen post on HPT that says they or at least running it as a standalone, but never any details on how.I thought you couldn't disable VATS on an E69?
That's what I did. I'll try tonight again. I wonder if they cheap key and lock I bought from Ebay doesn't have the chip ??Every time I replace the BCM, I have to do 3 sets of 10 minutes.
Here is a video on how to do it. His idea of charging the battery might help?
