Briann1177
- Briann1177 Goblin Guru
Yes, ditto to what Chad just said. The fuel pump windings could be shorted out.
If it is only happening with the fuel pump plugged in, then is almost has to be the pump itself. Unplug the plug from the pump and measure the resistance on the same two pins of just the pump. This will help to verify it's just the pump.
Just to be clear, the total resistance is zero? Because if it's just low, say 35 ohms or something, they pump motor may be good. I don't know what the actual resistance of the motor should be at this point, but the point is, there is a difference between zero and low. I'm just covering all the bases, not trying to confuse you or anything.
Most likely the windings are shorted inside. And to be on the safe side, replace the pump.
Keep in mind I have a TC fuel pump, but I get 0.4 Ohms resistance when I measure between they gray and black wires. Also make sure when you measure resistances, you're on Ohms and not the diode checker.
The thought that the fuse only blows when you have the pump plugged in tells me there is something going on with the pump itself.
Interesting about the fan power wire. I noticed that mine also runs for about a second or two after I turn off the key, but I never thought too much about it because the engine eventually dies without any issues. I don't understand why the fan would even cause an issue.
As far as your reverse lights, you should have a backup lamp switch on your transmission. There should be a light green wire that runs from your switch, through your engine-to-body harness connector, and out to your lamps. You can shift it into reverse manually at the transmission side if you want to test your lights that way.
You may be able to put a diode in line on the positive wire. It will allow power to get to the fan but will block feedback.
Also the heat exchanger fan needs to run anytime the key is on.
