Ok, a while ago I shelved the goblin and got busy with other life activities (mostly other hobbies). Well, now I have a clear goal and a plan,
1st: I want to revamp the turbo oil drain. I am using the terrible setup that ZZP sells with their turbo kit that re-routes the oil drain line to the actual oil pan drain. DUMB. I'll be drilling and tapping the block in the usual spot that others have done (dumps oil near the girdle). I'm going to use a 1/2" NPT to 10AN fitting here. I'll also be using nylon braided 10AN PTFE hose for draining and will sleeve this with a 3/4" heat shielded fire sleeve since this hose will have to sweep back toward the turbo manifold. I'll be connecting this hose to the turbo with a 38mm 10AN turbo drain flange.
Things needed for this:
1/2x14 NPT tap
1/2 NPT to 10AN adapter
10AN PTFE hose
hose assembly tool (i hate using a pick on braided PTFE lines.)
2 10AN PTFE hose fittings: i chose 1 45-degree and 1 straight.
I will tackle this project by pulling the oil pan, drilling and tapping the block, then installing all the necessary parts when I get bored.
2nd: I want to get the Dyemond fab air intake manifold. I want to do this because I will be redesigning the PCV system in the future and I want to delete the PCV valve that is in the stock intake manifold while doing this.
3rd: I'll be designing a catchcan system. I'll use 2 non-ventilated catch cans for this. one vent route will be coming from the oil cap (i have an LS oil cap with 10 AN fitting integrated in it that seems to fit well.) and the other will be coming from the new intake manifold. I'll have check valves in line where appropriate.
4th: full conversion to air-air intercooler. This will be a big project. I haven't decided where to locate the intercooler, or if i'll need fans on the intercooler, consequently. I do think I could put it in-between and behind the heads of the seats above the engine, but I'd definitely need to extend my nine-lives wing about 7 inches higher or so. These extensions are probably something Send-cut-send could produce cheaply.
5th: exhaust. I have no idea what to do here, but I do know i want to do something with it.
I'll start with project 1 and work my way down the list. That's all my thoughts for now.
If you have done the turbo oil drain project I am about to start, please give me any pointers you may have!
