Has anybody done their own valve job? Or do you know where I can rent machinist tools from?
I usually use a machine shop, but am considering buying the tools to do it myself.
It requires a
6mm ream, 6mm
Tapered Pilot, Valve Seat Cutters:
31° & 46° &
60°
Sometimes I shoot myself in the foot.
I'm trying to remove a cam shaft, and this allen head bolt is being stubborn. I heated the area with a propane torch, and kept working it, but it stripped. I tried stretching it to a torx head, but it is nice and round now. So off to the welder trick. I filled in the allen head with weld wire, built it up a bit,
then welded the nut on. That worked, the stubborn allen head came out. It was a short M12 set screw,.. here I thought I was struggling with a long M8 socket head.
I was thinking I won the battle... but no. That allen head wasn't needed to be removed, as the casting actually splits in half. Doh! Should have read the directions.
Measured the threads, and I bought a new allen head set screw M12x1.5-16mm long. That set screw was a plug for the oil galley that supplies oil pressure to the hydraulic lifters.
Well, the cams came out, as well as the rollers, hydraulic lifters, some retainers, valve keeper, springs, seals and 2 valves.
The old intake valve stem is 5.953mm, and the exhaust is 5.937mm. The new intake valve stem is 5.954mm, the exhaust is 5.947mm. Why more wear on the exhaust? The recommended oil clearance is 2 thou on intake, and 3 thou on exhaust, the difference in size is to allow the exhaust valve more expansion room, as it runs hotter.
