V1 Ross's extended city, easy entry Goblin- 06 SS/SC, NW Arkansas
I spoke too soon.
Behind the return check valve was a small filter.
54474
That filter was pretty plugged up, which caused the new pressure regulator to not work correctly.
54475
So I removed the check valve and filter, and the new regulator seems to be working.
54476
Thanks Jirwin. I doubled up the wires to the fuel pump, inside the fuel tank. I can run new wires outside the fuel hat, if I need the extra fuel pressure.
Cheap parts suck.
54582
Are the black aluminum threads strong enough to compress the brass ferrule?
No. :( I stripped 2 of them trying to get them to seal.
I decided to cut the fuel line to eliminate the 90 degree bend.
54581
So that the fuel line can go down.
54580
Rather than having a 180 degree
54579
Ebay.. but Amazon, Walmart, and auto supply stores all sell aluminum ones. I ordered a stainless steel compression fitting that adapts to 3/8" NPT, because i couldn't find one that adapts to AN6. I will adapt the NPT to AN6.
Dumbasses...brass is about 15-20% harder than aluminum. Doesn't take a genius to not understand this, but there they are selling parts that are incompatible for the application. Plus there will be galvanic corrosion between the bronze/brass and aluminum. Double dumbasses.
I modified my hood to open without tools.
The back of the hood is held by 4 wing bolts. I welded nuts to the goblin frame.
54599
I welded some plates onto door hinges, and made the front pivot.
54601
Then attached a string. I should add pneumatic lifters... one day.
54602
Guess what the LSJ block weighs?
The block has 3 bolts on the top, 4 oil squirters, all the oil plugs and engine frost plugs.
Once thru the sonic cleaner, so only some oil staining left to scrub off. I will clean it some more tomorrow.
54615
Today I pulled out the flywheel, girdle, pistons, crankshaft, oil cooler, and the crank position sensor, knock sensor and oil pressure sensor.
54616
54617
54618
54619
The girdle weighs 21 lbs 6 ounces.
54630
The flywheel & 8 ARP bolts weighs 18 lbs, 8 ounces.
54631
The crankshaft is 35 lbs, 10 ounces.
54632
4 pistons and connecting rods, 11 lbs, 0 ounces
54633
The block is 51 lbs, 15 ounces.
Markm was closest, and Robinjo with tree fiddy ounces (21.875 lbs) was second. :)
True... if you want a race car. Add a performance puck clutch, and you need to get familiar with your clutch engagement point, otherwise you are stalling every time the light turns green. The race track is fun, but I want my car to have good street drivability.
Indy Lonnie
I have a Clutch Masters clutch and ZZP lightweight flywheel and have not noticed any negatives. Drivability did not change at all.
Setting up the drill press to the correct angle was a challenge, but tapping it was easy.
54687
54685
The AN10 to 7/8"-14 thread adapter didn't have a 1/2" hole thru the middle... but it did have enough aluminum that my drill could enlarge it to the larger 1/2" size.
54682
Here is where the new turbo drain hole pokes thru the girdle... a little bit higher up than the oil pan flange.
54686
