SOLD DF Billet Shifter Assembly New
RobC76
RobC76
Anodized Black $125.00 shipped to you.
I didn't end up using this billet shifter. I have all the pcs except the tunnel sections which you can get directly from DF. (Prices see below) Save yourself $60.00 remember you only need one of the mid caps.
Here are the tunnel cap prices:
  • $22 - P012 Tunnel cap, front section
  • $37 - P024 Tunnel cap, mid, standard length chassis
  • $39 - P033 Tunnel cap, mid, extended length chassis
  • $28 - P034 Tunnel cap, rear section
Thanks
duthehustle93
I only used the middle from my kit, so I still have the front and rear for whoever ends up purchasing this .. it's brand new/never installed, for $40 shipped?
David
Thanks
Ill take it, even though o have the group buy lol
Yep, that one should work. It will be mounted 'backward' with the cable mount bracket toward the rear. This will put the cable attachment points on the shift lever and the side2side lever on the rear of the shifter to mate with the shift cables.
You may want to trim up the sides a little, since the bottom mounting plate is wider then the donor shifter. Minimizing the overhang might save an ankle when getting in/out. I put pics in my build log from a while back showing what I trimmed it down to in size.
I will be drilling through the tunnel cover top plate and tapping the matching holes in the shifter bottom plate to bolt it to the tunnel. Might need one or two stabilization brackets to keep it from wobbling side to side in use. These would be welded to the side of the tunnel with matching bolts in the shifter bottom plate.
David
Do you only need the middle section? I bought the shifter so would like to know what I need to order. If I need the 3 pieces ill take the front and rear and ill order the extended middle section from DF.
