- Robf Well-Known Member
I'm in the process of installing stage 2 components and I'm stumbling some.
Are all 4 stainless braided brake lines supposed to be the same size?
My rear lines are long enough but the front ones are no where close. Probably need to be a foot longer.
Next up is the axle. There is a 1/4 inch gap between the axle and the transmission on both sides. On the cobalt that wasn't the case.
Stock shocks are rubbing against my tires.
Rims are konig 8inch 45 offset with 245 45 17 tires. I'm guessing my offsets causing that issue and I need spacers?
Last thing which it may be my eyes playing tricks on me but it seems like the passenger front wheel is on the outside of the passenger rear where as the drivers front is on the inside of the driver rear.
