V1 ToothMagician's Full Cage Country Goblin #493 - '06 SS LSJ Turbo donor
ToothMagician
I'm Having a problem installing the upper BCM mounting bolt. The frame keeps getting in the way. Any solves?
Shorter bolt for sure. Your bulkhead might be a little low so you might have drill another hole. I welded a bracket on the frame for the bolt to thread into since just attaching it to the thin sheet metal didn’t seem like enough.
Instead of the small second spacer in Rttoys picture I used a nylon locknut. That way when you inevitably have to get behind the BCM it’s just one nut. Without that you have to get an allen wrench back behind the frame in a hard to read position.
ToothMagician
Your results may vary, but the Dorman #20717 replacement pad was a perfect fit on my clutch pedal.
These were a great solution, thanks!
Couple things:
I added split wire loom to all the installed harness wires. I like how clean it looks.
45301
45302
I have an extra foam pad for the brake pedal. Lemme know if you need one. ***Claimed***
45303
Has anyone else had to do this with their fuel pump? I had to cut the edge of the plate to get past the connector. Good?
45304
I'm feeling a little intimidated, looking at the engine. There's, what I think is, an EVAP line or the supercharger bypass selenoid, but am not sure. Any thought?
45305
45306
I painted all the donor parts with high temp enamel paint... It's trash, flakes off with the slightest touch. Shoulda used Rustoleum 2x.. oh, well. I'm gonna bring the lower control arms, subframe, and anything that's for more than just looks to powdercoat.
Is there anything I can do now to the engine to make life easier for after the install. My plan is to get the engine components plugged in best I can using the videos, then put the turbo components together utilizing my donor photos afterwards to minimize confusion.
That's all I got for now, just want to make sure the engine is as prepped as I can get it before it goes into the car.
ah.b.normal - I'm getting that list together, I'll have a message for you sometime this weekend - thanks again!
Couple things:
That’s cool! I’ll get the bits together and send them ASAP. I’ll message you with the gots and the nots and an ETA.
ToothMagician
Alright... I've got everything labeled and feel about 90% confident I can put the engine in and get it hooked up correctly. Plan is to get it in next weekend
45330
Should the coolant return line be re-installed? I have no reason for this, other than the coolant overflow tank only attaches to the turbo if not.
45329
Am I correct in thinking that the main radiator and the intercooler are separate systems? The Radiator from the front just loops in and out the block, while the intercooler follows the diagram? I'm second guessing myself because I've seen some other digrams where the radiator and intercooler are in a circuit.
45328
I still don't understand the supercharger bypass solenoid. It's not plugged in on one side...never was. Under the electrical tape are two small vacuum line type plugs/receivers/connectors. Is it needed for a turbo converted car to run? I was utilizing the search function and saw somewhere that it has other purposes besides just running the supercharger. Should I just loop it, cap it, or delete it? Safe bet says cap it, but I'd like to lose any extraneous stuff.
The red plug is for the EVAP system, I'm gonna clip it out.
45331
Thats all for now. As always, thanks for looking
Main cooling and intercooler are 2 separate systems. On a cobalt, looking at the diagram it’s easy to mistake they are together. They are separate though. Some put the old school green coolant in the ic cooler so if you see a leak you can easily tell if it’s intercooler (green) or main cooling (dex-cool pink)
ToothMagician
Awesome, that makes things much easier. Any word on the coolant return line, seems odd it just goes into turbo and that's it?
ToothMagician
ah.b.normal - here's that short list of bolts and miscellaneous things I'm on the hunt for. I think the kid who had the car before me liked to orphan fasteners on the garage floor when putting things back together.
(1) Valve cover bolt 10mm:
45342
45343
(1) Valve cover washer with bushing:
45344
45345
45346
(1) Trans housing bolt 18mm:
45350
45351
(4) Ignition coil cover bolts GM Part #12789897 (I have 0 of these, so I couldn't check the head size or take a photo next to the tape measure):
45348
45349
Here it is in written form for ease of use:
(1) - Valve cover bolt 10mm
(1) - Valve cover washer with bushing
(1) - Trans housing bolt 18mm
(4) - Ignition coil cover bolts
Thanks for checking in on these for me, much appreciated!
Yes, separate systems. The engine radiator normally is around 180F,
and the intercooler radiator is normally ambient air temperature.
I still don't understand the supercharger bypass solenoid. It's not plugged in on one side...never was. Under the electrical tape are two small vacuum line type plugs/receivers/connectors. Is it needed for a turbo converted car to run?...
The vacuum lines on the bypass supercharger solenoid are used to operate the bypass butterfly valve.
The SC solenoid has 2 inputs (one is air pressure after the SC, the other is atmospheric pressure from that open port)
and 1 output going to the diaphragm that operates the SC bypass butterfly.
The ECU uses a PWM (Pulse width modulation) electrical signal to the bypass solenoid valve to command the SC bypass butterfly valve to 100% open, n% open, or stay closed.
Maybe this electrical PWM signal could be used to command the turbo wastegate or blow off valve solenoid? The nice thing about this electrical signal is that the ECU knows if there is an engine problem, and can put the car in limp mode, to protect the engine. In limp mode, no request for boost.
Maybe this electrical PWM signal could be an input to an electronic boost controller? Basically used as a boost command request from the ECU.
Those cool cover bolts, none stocked yet. I’ve not ever picked any of those. Then again, after a complete search, I may find I’ve got some on board, If so I didn’t remember. For sure I’ll mail the others this week. see below. Colors! Need your actual address!
ToothMagician
Sent you a message. I do like the pretty colors ooooh
ToothMagician
@Ross
I had to read your reply 10+ times to completely understand, but this is super useful info! Thanks for literally spelling it out for me. It won't cause a problem if I delete it but it could be something useful since its a PWM signal! Haha LEARNING!!
