Only had a few hours to spare on the goblin this weekend, but did a few things worth updating for.
Finished up some more front end wiring work, the steering shaft and clutch pedal install, fuel tank install, installed the engine harness on the engine, got engine off the stand, and played around with all the line/wire routing a bit more.
The steering shaft/clutch pedal did take some bending and sanding, but I eventually got it to fit. I started with the master cylinder in place, and made sure everything fit around that. It was a really tight fit, but everything moves nice and smoothly.
As for the wiring, I'm really a fan of this wire cover stuff that MR.812 also used in his build. It was exactly the solution I was looking for. It's all over amazon for pretty cheap (although I may have bought most the open box stuff ha).
The fuel tank install was pretty easy. I even got a new fuel cap! While I was back there, I found some bolts to fit for the trans/engine install. I think the 2 longer ones will still fit without bottoming out in the trans mount. With the spacers, they all appear to fall to the same depth. I was just making sure I have plenty of engagement for the threads all around.
The line/wire routing is close to complete. There are a lot of touch conditions for the brake/clutch line, so I bought some vacuum hose to slip over and act as a protecting sleeve. I don't see them moving much, so I'm sure it will last a while. Might just end up re-bending lines in the future for a better fit.
