V1 V8 Gobbler #511 (Extended Track, LSX powered)
V
My ocd seeing that says make it symmetrical lmao
I really wanted to make it completely symmetrical. But I don't want the alternator up top and I think this style puts me in between 10-15 gal. I'm gonna look at it some more before I start building it. Still have to order fuel pump, sender and filler neck
Jason d
Definitely guna need every inch for fuel with that motor lol and ya filling up every trip is trash.
An equilibrium hose tied between the uppermost point on each side of the tank will allow the air pocket on the non-fill side of the tank to contain fuel rather than air. I'm sure Joe has this figured out already. ;):cool:
M
very cool & great fab work, did you do any geometry analysis on the rear or copy the same attachment points as the corvette? just that the c5-6 corvette IRS has got very minimal camber gain and you may want a tad more.
V
Very good, yes I knew this going into it. I will be welding on 1/8 npt bungs to each side at the top and connecting them with a 1/4 stainless brake line.
V
Thank you for the kind words. I attempted to mimic the geometry from the c5 the best I could. However there were many things getting in my way so I settled for the best possible placement of the arms. If you haven't noticed yet, I actually swapped the left control arms/knuckles to the right side and vice versa. If I used the left rear c5 arms on the left side of my chassis, the mounting location of the upper arm would have been way too far rearward of the. Chassis to support any lateral force.
V
The main construction of the fuel cell is done. Still need to cut holes for the pump, level sensor, install the cross over vent and figure out the filler neck and fill cap. Also there's a sneak peek of the new wheels i will be running!
SmsDetroit
Sweet looking. Just an annoying thing to me is the fill neck on the passages side. Did you think about moving it to the drivers side?
