Briann1177
Congrats. When I get to the point of creating an OK registration thread, please don't read it out of curiosity.
Congratulations!! I think you’re the first to admit to biffing it. Doesn’t look too bad. Is there any damage to the frame or just the fiberglass?Well, that didn’t go like I wanted. My cousin came over and I took it out for a spin. I kept saying I think the tires are too cold, it’s only 34 degrees out. The right front locked up when I braked hard for the turn. I let off, counter steered, but the front slid up on the curb anyway. No leaks, should be an easy fix.
Nope, steering rack is fine. I’ve already fixed that, took less than 5 minutes. I must have pushed on the wheel and popped the snap ring out and it slid back. All I had to do was remove the 3 screws holding in the bearing and snap the ring back into the groove.Did the steering rack hit and push back or bend the mounting bolts?
What a that green piece below the radiator? Looks tweaked.
There seems to be issues with one side locking up and not the other with it. Is this a brake bleeding issue or because the Goblin is so lightweight in the front?
Not sure if it matters much but my coolant flows through the radiator opposite than yours. The drivers side goes to the top and passenger to the bottom of the radiator. I'm not sure which direction it flows off the top of my head but I would think it wouldn't purge the air out as easily if flowed the wrong direction.
I just did it according to the video and haven't given it any thought other than that but just noticed it was different so wanted to bring it up
