I was thinking the same thing. However, I think you still can hear the fuel pump run when the key it turned on and I don't believe he is hearing the fuel pump. It would still be good to check them. I had the connector for the brake and the clutch turned around and you could only start the car without the brake or the clutch pressed, if you pressed either of them (like you should for safety), it wouldn't crank.As I get ready to wrap my harness I sit staring at my clutch switches, It wont start without the switches plugged in. This might be worth checking out.
Thanks for the input. I did double check the BCM power cable (and fuse), both ok. Like I said above, I'm 95% certain I've got the clutch and brake switches correct, but I will check those again.Tried catching up on everything you tried....So, when I first got all mine hooked up I had no crank, no fuel pump but had a click as well. The fuel pump issue was the small battery cable with the (I think 50 amp fuse) wasn't connected, make sure to check the fuse as well. So had fuel pump sound now but still no crank, I jumped the relay with a wire and that ensured all my wiring was at least powered up to that point. The issue was the brake and clutch connectors were somehow switched. I swapped them around and it fired right up (with the clutch pushed in of course)
clutch is the connector with the light brown....Green....and orange wires
Not sure if you tried all this, I went back a couple pages but could have missed stuff
My issue with the 2009 that I had was similar. What I ended up doing was checking the ground pole of the crank relay and it turned out not to be grounded. Once I grounded it. It turned over properly. But. I'm not sure if that could help you or not.Got a little more testing done. Was able to jump the CRNK and CRNK/RUN relays and get the starter / fuel pump to run, so the main fuse box is getting power. Unfortunately, after wiring up the OBD2 port, it didn't get any power, so I can't check for codes until I figure that out.
I'll check that - it would explain why I'm not getting fuel pump or crank, but I don't think that would cause the OBD2 port to have no power. I've saved the diagrams for that system (once again, big thanks to Dan for sharing those) so I can hopefully track down the problem.My issue with the 2009 that I had was similar. What I ended up doing was checking the ground pole of the crank relay and it turned out not to be grounded. Once I grounded it. It turned over properly. But. I'm not sure if that could help you or not.
Congrats! I am in the process of moving as well. Bigger garage so thats nice. but my goblin work has stalled completely. Now everything is getting boxed up. I diagnosed my issues with one of these...I'll check that - it would explain why I'm not getting fuel pump or crank, but I don't think that would cause the OBD2 port to have no power.
In unrelated news, I'm in the process of signing paperwork on a new house finally. It has a 40x60 pole barn that was the PO's personal auto body shop. In other words, it has heat, plumbing, 220V, lots of shelving/workbench space, and even a paint booth. Unfortunately, I won't be able to move in until August at the earliest, at which point I certainly hope the Goblin will be finished, but I'm excited.
I keep meaning to pick one of those up... thanks for the reminder! Off to amazon...Congrats! I am in the process of moving as well. Bigger garage so thats nice. but my goblin work has stalled completely. Now everything is getting boxed up. I diagnosed my issues with one of these...
I didn't remove the connector, I just shortened the wires going to it, so I don't think I'd have missed one, but that's a place to check. Thanks.I wonder if you accidentally removed or didn't hook up your OBD power wire when you removed the dash-to-body harness connector and soldered the remaining ends together?
Ah! This is really helpful. I was having trouble finding that circuit, but I was thinking it was power from the BCM to the fuse box. I was actually testing the CRNK relay, which is separate from the CRNK/RUN relay, but the latter actually supplies power to the BCM through that pink wire (when told to do so by the yellow wire). That will hopefully be easy enough to figure out.I think I know which pink wire you're talking about. Pin 30 on the run/crank relay should always be hot because it's directly connected to the B+. It doesn't depend on ignition switch position. I understand why pins 85 and 86 on the run/crank relay might read ground, but I'm confused why pin 87 would show ground if that's indeed what you're seeing.
You probably noticed this already, but on the bottom of the relays there are numbers which correspond to the pins on the schematics.
