Well it fees good to be working on the car again.
I'm slowly wrapping my head around what is left and the best way to move forward.
The first big project is getting the catch can system set up.
After seeing how quickly other's catch cans are filling up, I've opted for a catch can that will drain the oil back to the pan.
The design is based on the Powell PCV Oil Separator
Here is a basic plumbing diagram.
The biggest hurdle with this set up is dealing with the PCV valve.
Its located inside the intake manifold, so you must remove it, tap and place a plug in its place.
You then drill and tap a hole in the top of the manifold in front of the plug, so you can add a fitting and hose to route it to the catch can.
This shows the PCV being removed
Tapping the PCV port with a 1/8 NPT tap and installing a plug
Drilling and tapping the manifold with a 3/8 NPT for a 3/8npt to 6AN fitting
3/8 NPT x 6AN fitting installed, with just enough clearance to reinstall the manifold bolt.
After the intake manifold work is done, I had to prep the valve cover and turbo.
After removing the valve cover and destroying the quick connect hose from the valve cover to the turbo, I removed the quick connect barb and tapped the hole with a 1/8 NPT tap so I could install a 1/8 NPT to 6AN fitting
On the turbo side, I was just barely able to fit a 3/8 Quick Connect to 6AN fitting
I still need to figure out how I'm getting the oil from the separator back into the oil pan.
The Powell system adds an AN port the oil dip stick tube. I don't know how to do that, so I'm thinking about just welding or taping a fitting into the oil pan.
With soo much of the rear of the car disassembled, I took the opportunity to remove the fuel tank, clean out the metal shavings and install the Centroid Fuel Sender.
Next up I need to re-assemble everything so I can figure out where to mount the separator and start making the lines.
