It runs, I posted to the facebook groups a while ago with the video too.
Wouldn't crank at first, found that I didnt have the engine grounded well enough. I'm going to run the ground cable from a bellhousing bolt to the frame.
After figuring that out it would crank but not start, I thought I may have put the cam sensor in 180* out of time, so I pulled that out and moved it 180* while pouring oil on my new transmission and painted engine.
Still no start, swap the coil harness with the other plug that fits the same, move the cam sensor back to where it originally was and hey it starts.
Now I need to get all my coolant lines plumbed, intake put in, install the tunnel cap, get the shifter all set and I'll be able to get my first drive.
Body panels are at the body shop for paint, the Ronies have my 5 point harness' held up in shipping for now. My goal is to maybe end up at the ecotechnation tail of dragon drive in October if work slows down. I've worked 10-12hrs days every weekday since May.
