The "AIR PUMP" space in the fuse box is empty, so nothing to pull.If there is an Air Pump relay in the box, pull it and retest. Assuming you don't have an Air Pump relay or the chatter is still there we will need to change gears.
There should be no load on the relay at all at this point, so the issue has to be a lack of current/bad connection getting to the relay or more likely to the PCM or a bad ground to the PCM. This problem very may be upstream in the BCM or further as the instrument cluster is not acting as we would expect. It also bothers me that you had a blown fuse in the first place.
Small victories will win the war. Hang in there. I see some color blocks on the hood, are you still deciding on a body color?On another note, I really needed a moral victory this week, since I took the whole week off in anticipation of getting my first start in. I wrapped up the front suspension and brakes today, getting the car down onto its front two tires for the first time.
They need some camber adjustment (four complete turns out on all the outer rod ends does not seem right), and I'm sure the alignment is off but that's all down the road. For now, I am just happy to have gotten something done for the week.
The ground clearance is pretty good. Also I will have to find a way to prevent the steering wheel from being turned too far. Very, very close to the end of the range of the steering wheel, the inside of the front wheel touches the upper control arm. Will probably need spacers.
Yep, I threw on 12 (13) samples of Avery Dennison wrap. Some of them are immediate No's but a like a few of them. Leaning toward Rushing Riptide, Rising Sun, or Lightning Ridge, all in gloss, right now.Small victories will win the war. Hang in there. I see some color blocks on the hood, are you still deciding on a body color?
BTW, when the suspension is final adjusted be sure the heim joints are flat to ensure you don't have any binding during suspension travel - see the third photo you posted.
Yep, thanks, I've got them set aside for when I do my adjusting.Also make sure you put a cotter pin in that castle nut of the ball joint. Someone else on here didn't on a castle nut and part of their suspension let go while driving it. You certainly don't want that ball joint to drop out on you going down the road.
I'll give this a try tomorrow!If there are thoughts that there is a bad ground on the ECM, you can take another small wire, attach one end to the yellow wire at ECM X2/58 or fuse box X5/E2, and hold the other end to ground. If the chatter stops, then it could be as easy as the ECM ground. Or you could still have deeper issues.
I'm not going to be able to test running my own ground from ECM X2 pin 58 or fuse box X5 pin E2 until lunchtime, but I did retest ECM X2 1, 2, and 4, as well as pin H in the body-to-engine connector. All show continuity to ground.It looks like the grounds for the ECM are X2/1,2,4. Those three grounds join up and run through your engine-to-body harness connector on pin H and then to ground. So ECM X2/1,2,4 --> pin H --> ground.
Check all of those points too.
I'm looking at my '09 service manual. Your '08 might be slightly different, but I wouldn't think so for that particular circuit. I could be wrong though.Fuse box X5 E2 is, according to my diagram, a thick power wire for the ABS system...
Do you possibly mean fuse box X5 E5?I'm looking at my '09 service manual. Your '08 might be slightly different, but I wouldn't think so for that particular circuit. I could be wrong though.
Since you tested the ECM grounds, I'm not even sure how valuable of a test it would be to run that other ground wire. Fuse box X5/E2 should be the yellow wire that controls the low power side of the relay. The ECM switches a ground on that wire and that activates the powertrain relay. That particular yellow wire should go from ECM X2/58 --> fuse box X5/E2 --> powertrain relay.
If the relay is chattering, then the ignition voltage to the ECM should also chatter on pins 3, 5, 6. Depending on your voltmeter and how responsive it is, you might be able to detect the voltage cutting in and out. But I thought you said it was steady in an earlier post?
