So I started on the wire harness this weekend. It all started out pretty well. Got the table built. Marked the locations. Cut off the harness attachments and stripped the casing and tape. Went through the first thinning video without much trouble.
Then hit the second video and ran into lots of trouble. The video does not address back doors. Think I figured that out easily enough. But then I I found that I had no reverse light plugs.
We labeled EVERYTHING we disconnected. EVERYTHING. Even some things that didn't need labeling, or got labeled twice because it connected again somewhere else. No reverse light plugs. When we pulled the car apart, the wiring for the rear lights was quite different than the video. We had to take off the rear bumper to get the right taillight connector. IIRC, it plugged into the left, then went along the back bumper and plugged into the right . . . something like that. Anyway, one side had two plugs. We did not know what the second plug was for, but I'm thinking that plug HAS to be the reverse lights, right? But it is one plug. This one:
It has the same plug attachment as the left and right rear taillights had. I don't know. Just a guess right now. Any suggestions? I've left this plug attached for now, as you can see.
Then there is this plug:
It is labeled "powertrain accessory plug" which I would have gotten from the donor dissembly videos. Early on it had me cut the braided wire, but then nothing else, or I missed it (definitely possible). The brake lights come back to this light, as do the running lights. It isn't attached to anything else though.
Then there is the "Brake reservoir plug". Not mentioned either. I cut the ground to be able to remove a whole ground bundle of wires, but I can put that back on easily enough. Just not mentioned. Any thoughts?
Lastly, I have an automatic and this plug was not mentioned, nor do I remember it being mentioned in any of the harness videos. Someone had said to watch the old videos to find out what to do with it, but I have gone through 30 minutes of old videos and not see this connector mentioned.
I imagine it stays intact and gets wrapped up, but where does it come out of the harness? Do I need to lengthen it to get to that point? I'll keep going through the old videos, but if someone knows, please tell me.
So this is where things sit now and I do not want to go on until I figure a couple of these things out.
Thanks for your help!
