Lots to report as I work my way through this car. Progress remains slower than I'd like, mostly because life gets in the way, but also because there are bumps in the road build-wise nearly every step of the way. Learning is always a good thing though.
I decided to go with different wheel and tire package than what came on the partially-built car. Borrowing/stealing from
@JBINTX I went with this:
- Track tires 15x10 American Racer 23.5/10.0-15s (131 compound)
- Track wheels Aero Race wheel 50 Series 50-104550 15x10 with 5" back space (these clear the calipers on the 09 tc SS model), Day motor sports 800-543-6238)
- Track wheel spacer/adapter - 1" to get from the 5x110 to 5 on 4.5"
The supply chain is weird. I got the spacers right away, from US Wheel Adapters in Lubbock TX. I suspect these were the easiest thing to get quick because they manufacture locally and were probably not waiting for materials to arrive from off-shore, etc. Great guys to work with, recommended.
The Aero Race wheels came next, from Day Motor Sports. They look awesome, and arrived quickly. They are also made in the US in Estherville IA.
The long pull was the American Racer tires. I waited several months for those, and that turned out to be OK since the car isn't really ready yet.
I got the rear coil-overs installed, hopefully correctly sorted out the front tie-rod situation, and then turned attention to the front suspension. I've been eyeing things suspiciously up there for a while, mostly because when I received the car nothing was torqued to spec - in fact it was all mostly finger tight. So I decided to go through everything and check the assembly process, set everything to torque spec, etc. So I pulled everything off the car, and re-did it. And that's when I found this bit of bad news:
This is not only annoying, but it's really going to slow me down if this isn't field serviceable. The car came with 5x114.3 hubs, and I'm coming to learn that as a result everything needs to be custom ordered. I really hope I can get that mounting stud removed and replaced. It's not cast in to the piece, and it doesn't look screwed in. I soaked it with Aerokroil penetrant, and in a day or so I'll take a torch to it and see if I can then hammer or press it out. In the meantime I asked DF to quote me on a new hub just in case.
The car came with what was, to me, a strange wheel and tire package - two different tread types, large diameter with deep offset wheels, etc. I was scratching my head about why the original builder made these decisions. Then while I was digging into the front of the car it hit me....
These are the SS/TC donor car Brembo fronts installed on the Goblin, with big honking rotors. These are not going to work for several reasons. First off, the new wheel/tire package won't clear the assembly...no real surprise there I suppose. More importantly, the Cobalt SS unladen/empty weighs something like 2,975 pounds and I believe when full of fuel, luggage, passengers, etc. can go up to 3,900 pounds. So it needs a LOT of brake to pull that down from speed. I am guessing that our cars will weigh in around 2,200 pounds, so these will massively over-brake the car. That's never fun, leads to lots of wasted $$ on flat-spotted tires, and arguably isn't as safe as something you can pull down hard without lockup.
Included with all the various pieces-parts that I bought was a pair of smaller calipers, intended to be used on the front of the car:
The Brembos are now off the car - I'll toss 'em on a few lists for sale - and these smaller calipers will go up front. Of course now I need different rotors, and rooting around the forum it seems the only path forward there is to source them from DF. I'm waiting to hear what they have for me.
I bought the shifter setup put together by some builders a few months ago and that hasn't gone onto the car yet. DF has since release a revised shifter kit that looks cleaner/better. I'll be selling the "group buy shifter kit" and installing the DF revision. Both are sitting on a shelf in the garage.
Finally, since this is a full-on race car with no intention of street use, I've decided to sell the Corbeau FX1 seat package that came with the car in favor of Kirkey 65 Series race seats. These will be a bit lighter, but also give me an added margin of safety. I'll replace the harnesses with date-fresh FIA certified harnesses before I put the car on track.
While I wait for front end brake parts to show up, it's time to turn my attention to the task I'm dreading most - installing the wiring harness, fuse boxes, and ECUs. I have a DF-made wiring harness and that should make things easier, but i'm really stressed about this work.
