Clutch and brake bleed question
Joe, you should add that your transmission is a F40 and has different dimensions to contend with than the F35 or F23. The dual mass clutch is thicker in height than the single mass clutches and the pressure plate engagement location is the variable you are trying to accommodate.
Plus getting the throw-out bearing to not touch when not engaged.
