The back going to the engine
I did something similar on my build:Use high pressure (60psi or higher) rubber fuel hose to clean up the the fuel hose routings. Cut the ends off the stock hoses and attach them to the rubber hoses. I also cut the plastic line off the car from the quick disconnect on the engine to the metal line going back to the fuel tank. I spliced that in for a clean look from the filter to top of the engine.
yep, a clock spring for the air bag. Not needed.
Looks good and seems easy enough. Thanks!Use high pressure (60psi or higher) rubber fuel hose to clean up the the fuel hose routings. Cut the ends off the stock hoses and attach them to the rubber hoses. I also cut the plastic line off the car from the quick disconnect on the engine to the metal line going back to the fuel tank. I spliced that in for a clean look from the filter to top of the engine.
You guys are always making me spend more money!Would wholeheartedly recommend getting the parking brake kit, having a 5-speed with no parking brake strikes me as unsafe as hell, lol!
