Scott Geyer
Anybody running E85?
This is why I haven’t switched. Where I’m at, e85 is hard to come by. Hell, where I am, I can get e free fuel (90 octane I believe). That’s what I run in my lawn equipment and anything else that sits, plus it’s been known to trickle its way into the goblin, so I don’t have to stop at a gas station.may not be great for long roadtrips in areas without good access.
What did you have to do to get this to run as far as added equipment and programming? I'm curious about running e85 on my LSJ.I'm running E85 as well with a SS/SC. So far only autocrossed with it, but it certainly seems to eat it up quick! Great for performance, may not be great for long roadtrips in areas without good access.
Injectors and tune are about all you need.What did you have to do to get this to run as far as added equipment and programming? I'm curious about running e85 on my LSJ.
ZZP told me you also need to replace the fuel pumpInjectors and tune are about all you need.
Good to knowI'm running a ZZP E85 tune on 80# injectors and a GM stock pump just fine.
