Also, when
@Gtstorey says "compare", he probably means the actual compare feature in VCM Editor. You open the tune file you want then click Compare -> Open Compare file.
Then you can go to the same menu and "View Comparison Log" to see a list of all the differences.
Helped me a lot in understanding what ZZP is changing between tunes on mine.
Also, here is the channels/layout file ZZP Gave me. It says 2.2/2.4, but it seems to have most of the stuff any setup would need. Would be a good starting point if nothing else. FYI I had to rename them as .txt to upload them here. Remove the .txt in the file names.
