MX184
How hard was that to wire up? I'm thinking of going haltech dash when I turbo my car.You could use a race dash from AIM, AEM, Haltech, but they get pricy.
This the AIM MXG in my build.
I guess it’s a bit relative.How hard was that to wire up? I'm thinking of going haltech dash when I turbo my car.
What motor do you have?So here's a question. I found a brown wire in the connector for the gauge cluster, figured since I'm not using it why not use one of the wires if it works. When my car is completely off it reads 12v. When I turn the key to accessory it goes to zero. Is that normal? Am I just using my meter incorrectly? I'm just having a very difficult time finding a switched 12v supply for the AEM meter. Seems like everything I try is either continuous 12v or less than 12v or acts like the wire I described above. I'm not good at wiring if you can't tell already. Is there a clear and straightforward way for me to find a switched 12v supply? I finally have the tools to fix my engine and now I just can't figure out how to power it which is supposed to be super easy. I have to be screwing something up.
Did you have one wire from the electrical meter on 12V-/ground and the other meter wire on the brown wire? This is how you should be using the meter.So here's a question. I found a brown wire in the connector for the gauge cluster, figured since I'm not using it why not use one of the wires if it works. When my car is completely off it reads 12v. When I turn the key to accessory it goes to zero. Is that normal? Am I just using my meter incorrectly? I'm just having a very difficult time finding a switched 12v supply for the AEM meter. Seems like everything I try is either continuous 12v or less than 12v or acts like the wire I described above. I'm not good at wiring if you can't tell already. Is there a clear and straightforward way for me to find a switched 12v supply? I finally have the tools to fix my engine and now I just can't figure out how to power it which is supposed to be super easy. I have to be screwing something up.
No, that will work, but you can also pick up the ground by any bare metal on the chassis.I have the LSJ.
I put one terminal on the neg battery terminal and the other on the brown wire. Maybe that's my issue? Should I be using a ground from the frame?
Good point.Red/white wires are fused, constant 12V+, Pink are fused and ignition switched. I would want the wideband O2 sensor to be ignition switched.
