OptimizePrime
Linked below is a guide for registering in Montana. Few things before you get started:
1. There are many factors that play into your individual build that would dictate which route to take. I won't speak to the pro's and con's of the decision, this guide is focused on HOW to do it with the least amount of headaches.
2. I'm not compensated by the registered agent listed. There are quite a few registered agent options out there with different services, costs etc - choose the one that fits you best.
3. Your donor, more specifically - how you own your donor, may cause you to take a slightly different path than what's outlined below. You could still use aspects of what's below, but you may have to freestyle it a bit to get to the desired end result.
4.DO NOT REQUEST AN MCO OR ODOMETER STATEMENT FROM DF BEFORE GOING THIS ROUTE - This is no longer the case. You have to get the MCO written out in the name and address you purchased your kit with (for most of us, that'll be our human names and residential address). It may benefit you to create an LLC before purchasing your kit.
Hope this helps! Would be interested to hear how your Montana registration process was different from below.
docs.google.com
4.
[GUIDE] Montana
Before we get started: 1. There are many factors that play into your individual build that would dictate which route to take. I won't speak to the pro's and con's of the decision, this guide is focused on HOW to do it with the least amount of headaches. 2. I'm not compensated by the registered ...
