GoblinGuyZ
For security I just take my wheel inside with me when I go to work or anywhere else unattended for any length of time.
ON another note, just started playing with my AEM Dash with the 10hz GPS, I have the performance timers set for 0-60 and 1/8 and 1/4. They are set to reset on a dead stop and to start timing from anything above 1km/h movement so pretty much as I get moving.
Just outside where I am there is a relatively empty level road I use not far from home and today I got to do my first attempt at a launch.
Cold tires, Toyo R888R, 80F temps outside. Launching from maybe 2000/2500 rpm nothing crazy.
06 SS SC with
ZZP LSJ Stage 2 Kit with 3.0 Pulley
ZZP Dual Pass
M62 Supercharger spacer
ZZP Coil packs
Iridium Plugs
ZZP Shorty Exhaust Manifold
Custom VIbrant Exhaust
Vehicle needs tuning as its the stock map sent with the Stage 2 kit thats for a Cobalt not Goblin so I still have to do the remote tune on the vehicle.
I'm estimating somewhere in the 240/250 hp range maybe.
Tire pressures are around 17psi rear but will play with that some as well.
Anyway for first and only attempt I got a 4.1 0-60 with a good bit of wheel spin on launch so if I can hook up for sure will get well below 4.
1/8 mile was about 7.6, road isnt long enough or safe enough for me to try 1/4 will do that when I get to a track. Just thought I would post real world results but as mentioned it was my first attempt and no doubt can be improved on a good bit especially with warmer tyres and a better launch etc
06 SS SC with
ZZP Dual Pass
ZZP Coil packs
Iridium Plugs
