jayrolls
Assembly Day - 12
Installed a Motive pressure bleeder. Found a small leak on the front brake line on the brass fitting to master cylinder adapter. Will have to correct that. Was able to start at the R/R and work my way around and got great results. The pressure bleeder made bleeding the brakes fast, easy and a one person job. Will use thread sealer on the brass fitting and then will double check the system for leaks. So ready to be able to put the wheels on.
