Been a minute since posting. Slow going now that it’s High School wrestling season. Coach Life.Assembly Day -16
Its been a productive day. Set the rear camber @ Neg 1.5 on both sides. Adjusted the front camber to the same Neg 1.5. L/F had to turn the heim joint out about 2 1/2 turns, R/F had to turn 1 1/2 turns out. My toe plates didn’t get here yet, so I am just kinda eyeballing it. For the most part I feel I have the steering wheel pretty centered and tracks pretty good in the neighborhood.
Tapped the tunnel and ran allen screws to secure the tunnel cap. Went rather smooth, the far back two were a little harder, self imposed due to having the rear bulkhead already installed.
Installed the passenger seat, bolted both seats down. Op-check of the passenger heated seat checked good. Notched the footwell cover to clear the clutch master cylinder and clutch and brake hoses. Still need to drill holes to be able to zip tie in place.
Ran the power wires to the AEM air/fuel meter. Tied in at the BCM using a fuse adapter to have key on power.
Another few steps forward and 1 step back. So it appears transfer case out out shaft seal that goes on the right cv shaft. Needless to say, when I got the new shafts I did not realize this was a thing. While cleaning up the garage today, noticed it on one of the old shafts. So it looks like I am going to have to pull the R/R so I can install.
Looks like BFGoodrich g-Force COMP-2sWhat tires are you using I like the looks of them .
Thank you
Zoom and K. Rollin, that is correct. They are the BFGs G-Force Sport Comp-2s.What tires are you using I like the looks of them .
Thank you
I put the OEM tune on yesterday and let sit overnight to test my cold start symptoms again. Tired to start and engine sounds like it is sucking in air and fails to start and run. The 3rd start it sputters and then stalls, the 4th start it will start and stay running and is drive able. Didn’t take it out tonight, a little colder than I would like. Starting to wonder if it’s fuel related. Like it takes some many starts because it is building fuel pressure.Took the Goblin out yesterday for a little run, did great on the way to our friend's house. Left late and it was cooler and damp humid out, car ran like crap. Had trouble getting it started, was sputtering and falling on its face. Got warm and then seemed to be better on the ride home. I have taken it out a couple times today and attempted to get some data logs. First my AFR gauge with pass through caused there to be no data displayed on VCM scanner, so these two runs are with the AFR not pulled in with HPTuners. If anyone could please take a look at the data logs as I honestly don't know what i am really looking at yet. Just that it doesn't seem like she is running the best that she could. Any help is greatly appreciated.
Not to my knowledge. I will check ALLDATA and also see if that is something I can see in VCM scanner. I may have to use an old school fuel pressure gauge and check it on the cold start symptoms.Does it not have a fuel pressure sensor?
Looking in ALLDATA my model does not. States to use fuel pressure gauge to test for proper pressure.Does it not have a fuel pressure sensor?
It’s a new fuel pump with maybe 20 test miles now. I did a new fuel filter with the build, I didn’t do a boost ref system. I did install a new fuel rail, pressure regulator and new injectors.As far as I know the SS/TC is the only Cobalt with a fuel pressure sensor.
I know on the first key-on (without hitting the starter) the fuel pump primes in my car. I can't remember if I can prime the fuel pump more than once without starting (by going key on engine off - key off - key on engine off), and unfortunately my car is apart so I can't test for myself. If you can prime the fuel pump more than once, does that impact starting?
Did you put a new fuel filter on your build? Any other fuel system modifications, like a boost reference pressure regulator?
Ross,Jay, I took a look at your xmas log file. Do you have a wideband logged? I am only seeing the stock narrowband. I see your long term fuel trims are indicating your engine is wanting to run rich at low manifold pressure (20 - 50% of atmospheric or 3 to 7 lbs/in^2), so the LTFT are near -20.
Not sure what that means, or even if it is significant.
This summer my fuel system stopped keeping pressure when the engine is turned off. I am guessing there is a check valve that has failed in my fuel system... but I hear the fuel pump running when I turn the key. If I turn the key to crank the engine before the fuel pump gets up to pressure, my engine won't start. If it turn the key on, wait 3 seconds for the fuel pump to get up to pressure and stop pumping, then turn the key to crank the engine, it starts every time. Not sure if this is your issue, but try it.
You local auto part supplier can probably loan you a fuel pressure guage for free. My engine runs 59-63 PSI fuel pressure, only dipping slightly under full throttle. I used my AC guages to monitor my fuel pressures for a quick test. Had to drain fuel out of my guage set afterwards.
Jay, which model is the 'wrong' one - that I assume doesn't have data logging?Ross,
I bought the wrong AEM AFR with the obd2 pass through, I can only watch it as I run it. I will give it a test if I turn key on and wait for the pump to stop priming. If that doesn’t do it I will get a pressure gauge and test.
This is the one I purchased thinking it would work on my 07. It’s for an 08 or newer that uses CAN BUS. I think there is a basic one that wires in differently that works with HPTuners pro features.Jay, which model is the 'wrong' one - that I assume doesn't have data logging?
