JCas Tacoma Wa city easy entry 07 LS #188 "REGISTERED"
Jcas
Oh! Almost forgot- if that's an '04 Redline, it doesn't have an LSD. They only offered the competition package (with gray wheels, boost gauge and LSD) from 2005 on.
I do believe how ever that it is a bit higher geared than my current trans which if so would make the freeway a bit more enjoyable as 3200 rpm for 75 mph gets on your ears after awhile. Along with that I think I have a problem with second and a bit more noise coming from the gear box than when I first started driving the car. Maybe I should not be so hard on second.
A 4.05 final drive F35 (LSJ spec) should be 175 RPMs higher at 70mph than a 3.84 final drive F23 (non-XFE N/A Cobalt spec) on a 25" tall tire. What size tires are you running?
CajunJeff
Looking at Rockauto the do show NON Abs hubs for front and rear
All year Redlines had ABS, some of the base model Ions had rear drums and no ABS. None of them had traction control. That sensor on the intermediate shaft is the speed sensor, and was only on the '04 models. You will need a dealership or someone with HPTuners to change the speed sensor setting in the ECU.
(EDIT: If you just want to swap in the drivetrain from the Ion, that's doable, but probably more work than you'd like)
https://www.redlineforums.com/threads/04-speed-sensor-to-07.89746/#post-1314888
SmsDetroit
I guess I’m lucky. Mine is a 09 as/tc I put 275/40r18 on the rear. Just took a hour drive on the highway at 80 and my rpm held at 2800
Jcas
I am just concerned about the tranns I have currently in the car seems more slop in the drive train and more noise like a bearing going south.
Jcas
So Guess what. I get to build another Goblin. Not sure if we want to jump up for joy or .... The first was fun but we had our little problems but we sure have enjoyed every second of the drives. Now the Nest builder wants one of her own. So I have brought home another 2007 LS in a automatic. As we progress with that one I will keep you all up to speed and I think we will just share it here with the first. This one should be more fun as I am going to make the Wife do more and Me less. Which will let me take more pics to post here. So many things I wish I would have shared but I didn't think about it until I was on the other side of the project.
