You've undoubtably been there. They we doing a bunch of gear changing as well. Followed by a bunch of crap talkin'a little sound bite needs to accompany the first pic.........vrooom vrooom
For the SS/SC version a lot of the builds put their cold air intakes there. There are a couple of TC versions too. Not sure what you have planned. I think I'm going up, snorkel style.I'm struggling with a few of the decisions. For example.
I want to put the transcooler here, but I'm not sure that will be its final spot. I want to do as much of the welding as possible now, before we coat, but know I may need to move it later to fit other things.
I'm TCed and plan on up somewhere around the fuel filler.For the SS/SC version a lot of the builds put their cold air intakes there. There are a couple of TC versions too. Not sure what you have planned. I think I'm going up, snorkel style.
The 2 tubes that I point out in red, have holes predrilled for rivets to install the firewalls/bulkheads. If there was a leak into those from the lower frame tube, my pressure text would have failed.I'm one of the others considering running coolant directly through the tubes. I need some clarification. I never considered the lower tubes might have holes in them where the other tubes are welded on. Are these holes there by design? if so, why? If not, how do they get there?
see the thread and post #37Does anyone have any ideas on what kind of fitting I can put in the valve cover for my external pcv valve and catch can system? Preferably somewhere in the red boxes so as to use the stock media.
I wish.Nice size oven, looks big enough to hold a whole Goblin frame.
I see a pneumatic riveter... I wish I had used one for my build.
I only have the firewall left to rivet and still considering getting one!I see a pneumatic riveter... I wish I had used one for my build.
