Sluggonaut
Availability is the only problem I've had with E85 when traveling outside my home area. At Goblinfest last year I had to drive 25 miles each way to fill my fuel cans.
What ethanol content are you tuned for? I want to switch to E85 but the inconsistency has me concerned.Availability is the only problem I've had with E85 when traveling outside my home area. At Goblinfest last year I had to drive 25 miles each way to fill my fuel cans.
Michigan has a good # of stations. Traveling could be trickyAvailability is the only problem I've had with E85 when traveling outside my home area. At Goblinfest last year I had to drive 25 miles each way to fill my fuel cans.
My thought was to just get a couple 55 gallon drums and fill them up at the pump and then tune it for that so that at least it's consistent. I believe the content depends on the weather so if I just wait until late spring to fill up it'll probably be pretty consistent throughout the summer. I just wish our ECU had flex fuel capability.I'm not sure what it was tuned for because I'm running the E85 tune that was already on the donor from ZZP. I've just been running pump E85. I did buy a test kit but haven't used it yet. I've been logging AFR's and haven't seen anything to worry about yet.
The old LSJ will adjust fuel trims. A modern GM flex fuel vehicle is a whole new thing that I am not knowledgeable on.Ask the experienced tuners on HPT what they think of GM’s “virtual” flex fuel.
If all it’s doing is adjusting fuel trim, is there any benefit to running It as flex fuel, other than the possibly cheaper fuel? Without timing adjustments is there any power increase? I guess maybe the cooling effect helps a little?
Sorry, I thought you were talking about it being able to adjust for all ethanol contents, not just the variance in E85 or whatever particular E blend.The old LSJ will adjust fuel trims. A modern GM flex fuel vehicle is a whole new thing that I am not knowledgeable on.
I would have a proper ethanol tune on the LSJ, (timing included) and then let the fuel trims do the gas station fuel supply differences.
Guys at ZZP said you can gain a good 40hp. They recommend changing the fuel pumpSo there's a few things here that are interesting from a few folks. I love my E85 setup, so maybe can shed some light with what I've come across.
The fuel doesn't exactly end up cheaper in most cases, but there are benefits to running it. When I say in most cases, it's all about cost per mile. E85 is less energy than regular pump gas, so you end up using more. Your energy deficit from E85 to pump gas is somewhere about 25%, so quick math at the pump can usually tell you what is the better deal. I used to play this game all the time in my suburban: that was half for value of pulling up to the yellow handle, and half if I was planning on towing something.
Speaking of towing, there's the E85 benefits. The octane rating on E85 is much higher than most all pump gas, so anyone running a boosted setup (or in my suburban case, towing and extra load on the motor) can benefit purely off the lack of detonation potential. That said it is MUCH cheaper than premium in almost every case. The issue being that premium tends to be better controlled and more readily available.
E85 can make more power when properly tuned, but this enabled by the octane rating and being more aggressive with timing. The "blend" at the pump can vary in Michigan from somewhere around 51% to somewhere around 83%. The pump usually tells these as a service announcement of sorts to consumers that I can't quite remember the numbers so these may be a tad off. This also depends on time of year when it's winter or summer for different blends to efficiently run in the cold.
In any case, I've ran a lot of E85 and always had it be +75% from the pump. Maybe that's luck, or Meijer has a great stock of corn. Either way that's why I stopped buying 5 gallon buckets of E85 specific race fuel and started going to the pump for it. It works just fine, and they are around Michigan everywhere. The Goblin seems happy to run off it too!
How are you checking the ethanol content? Flex fuel sensor or test tube?So there's a few things here that are interesting from a few folks. I love my E85 setup, so maybe can shed some light with what I've come across.
Both ways actually. Was really curious just how good the expensive GM sensor in an '05 truck really was. Turns out they were expensive for a reason. The new sensors are much more cost effective, but that's technology advancement for ya.People that
I'm getting around 14-16 MPG on my E85 setup.Fuel pump and injectors are basically a requirement with E85. Easy swap, easy power, not many long drives for the Goblin (honestly really curious to see my mileage once I hit the streets to cruise around given all the changes I have from stock).
There are but they really do not benefit the performance minded people. IIRC pump E85 is allowed to be anywhere from ~50% to 85% ethanol witch makes a flex fuel sensor and flex fuel capable ECU extremely beneficial.Is ethanol content wildly different from day to day or place to place? I just assumed that it was pretty stable. That there was regulations and standards to the e85 fuels. I've not jumped into this realm (yet) so I'm asking strictly for knowledge.
I have a link just a little further down that can help extend your drives, but it does unfortunately require some rearranging of parts.Also yes, you do need to push more fuel to even get the car to run right. Fuel pump and injectors are basically a requirement with E85. Easy swap, easy power, not many long drives for the Goblin (honestly really curious to see my mileage once I hit the streets to cruise around given all the changes I have from stock).
