The yellow doesn't have power when the key is on. The pink does.
I was hoping this thread could help me out. I'm having similar issues on my LSJ with no crank when turning the key.
Here is what I get at the clutch switches:
Key on, clutch NOT pressed:
Yellow gets no voltage
Pink gets 12 volts
Other switch:
Pink/black gets 12 volts
Brown/White gets 12 volts
With Clutch pressed:
Yellow gets 12 volts
Pink gets 12 volts
Other switch:
Brown/White gets no voltage
From the info above, this looks correct, but I still get no crank.
The only thing I get on the digital display is low coolant and low brake fluid.
Engine will crank by jumping the battery to the starter.
Throttle body works great.
Fuel pump does cycle, but I have no fuel in the tank yet.
Accessories switches work, along with front lights, turn signals and horn. Rear taillights are not hooked up yet.
I have a dedicated ground wire going from the battery to the pedal box to the tunnel ground to the engine which checks out.
Any thoughts?
