No just stock
I would feel a lot better also with his experience with cobalts and goblin builds
Adding to what @Ross said, in HP Tuners under System -> Coolant Pump you can adjust the parameters for the intercooler pump operation. ERT Min is Engine Run Time Minimum before the pump can start. Then it just has to be above the IAT Min for it to run. As info, stock is 10 seconds and 5 degrees IAT. So you should have power continuously after 10 seconds unless you live in the arctic. I altered mine since I am using that wire to power the intercooler fans. I use a Setrab thermal switch to control my oil cooler fan.Does anyone know when the pink wire you put in for the IC pump goes hot? I was thinking about using that to power the fan on my external oil cooler i'll install this week.
Nuker-
Good point... I just looked at a LNF file and do not see it anywhere...Does the intercooler pump settings apply to the TC version? I just started looking at the available tables last night and don't remember them being available. Of course I wasn't particularly looking for it.
Good point, I'll stick a meter on it, it very well might go hot right away. Thank you everyone.The intercooler wire on the TC was repurposed, but I don't remember what it was for originally. I think it goes hot immediately, but I haven't checked that.
